Does anyone have a part number for a mini alternator. I need one for a low mount on my 283 chevy on my t-bucket.
What is the part number and manufacturer?
Do the low mount brackets require a mini to fit or is it just for looks and space saving?
At least yours fit, mine is below the frame rail.Here's what a regular-sized alt looks like. Very tight... maybe 1/8" clearance at best.
Mounting the engine too low in the frame (pan too close to the ground)all because of the trans and drive shaft hump, is not a good reason really... That can be worked around, but a busted pan or starter ring is a nasty fix and at the wrong time a real nasty all around headache...If you place your motor high enough in the frame it'll be fine but I know some mount it low to help with the trans hump in the floor.
Mounting the engine too low in the frame (pan too close to the ground)all because of the trans and drive shaft hump, is not a good reason really... That can be worked around, but a busted pan or starter ring is a nasty fix and at the wrong time a real nasty all around headache...![]()
If your not going REALLY FAST all the time i dont see how this is a good idea.I do alot of cruising and just plane putzing around so my battery would for sure go dead.I dont have the room either for a four foot pulley under my car to adjust for the lack of rpm's.Ever though about this for an alternative? And yse it can be done with a live axle
[attachment=4041:Alt-postion.jpg]
Gerry
Are you using my name in Vane?LOL
