Bugflipper
I've been trying to read up a lot on this board before posting. It looks like a lot of folks recommend edelbrock carbs for reliability. I have only ran one and it was years ago. It would sit and the fuel would dry out. A few wraps with a wrench and it would knock the varnish loose and be back in business. If I let a Holley setup like that it would need at least a cleaning, usually a rebuild. The edelbrock was down on power compared to a 4150. But it ran decent. I was wondering if 20 or 30 years has made the holleys more reliable? A lot of times they would flood the top of the intake if a bit of trash got in. Also wondering about these AVS edelbrocks? Would that be a benefit at all?
Here is the angle I am thinking from. I have a 327 290 HP. It's been mildly built years ago with a .455 lift cam. Upgraded to hei. Has some sprint style 1.75 headers and old school wieand accelerator high rise single plane. Most likely it it in the 375-400 range at the crank I am guessing. It has a 750 4150 which is of coarse to big. I'm running a th350 and a 3.40 something 10 bolt rear on 12" drag tires. The wieand isn't a torque monster down low. Was thinking the AVS carb could play on that a bit. Tighten up the secondaries a bit to keep from breaking the little tire loose out of the hole and let them have som power somewhere above 3000. Any thoughts on this or would I be better off with a different carb. Without looking I think the AVS may be a 650. I've ran a similar motor with shorter try y headers and a 600 4150 with decent results. I really just don't want to tinker anymore. I heard the edelbrocks are flow tested with air only so that is why the 650 question. A 570 or 600 Holley would be about right. Don't know about edelbrocks though.
