Hello Everyone,
:bawl: newbie here,
This is an introduction as well as a front axle question. I am new to the building of T-Buckets, HotRods, and Crusiers but I have fabricated various parts and accesories for Off Road 4 x 4 vehicles form buggies to 7000 pound full size Chevy K-5's.
I have taken a great interest in rewarding myself for my two years, four months, and thirteen days of sobriety. This reward comes in the form of building my own T-Bucket from the ground up by way of what I refer to as "traditional" methods. I will be resourcing parts from as many possible salvage/wrecking yards as I can and purchasing some parts such as axles, rear end, interior peices from various sources in the used form. Safety is of course at the top of the priority list for myself, my family, passangers, and those I will share the road with.
I DO NOT wish to nor have the means to drop upwards of a couple thousand dollars on a front end set up from a well known after market source. It would be nice to be able to, it simply is not the case. I do realize that alot is to be learned, it will be very time consuming, and that some items will have to be purchased new for the sake of safety.Other than those specific items related to safety I am looking to build this vehicle in the "traditional" scavange and search method. This is also an effort to spend quality time with my wife rediscovering this Great Country as we search out or parts for the build. Knowing that a vehicle can be built safely and very much road worthy through this method, it is the approach that I prefer.
I will be building a basic classic T-Bucket frame from 3 x 2 .160 rectangular tubing, running a GM rear end most likely from an S10, an automatic transmission, (my clutch leg is much bigger than the other lol) and of all things a Four Cylinder GM 181 engine. I have acquired some of these parts such as the engine, trans, and the two front axles, one being a 47-55 GM 1/2 ton truck axle with springs, drums, and spindles, I also have a 1930 Model A bare axle.
My question is what are the pro's and con's of each axle set up? I would like either the traditional spring behind or a "suicide axle" set up. RPM makes a bolt on adapter for my GM axle to set it up for the radius arms and spring. I have seen different options for the Ford Axle such as bolt on spring perches that incorperate the classic "batwing" and I like this idea.
Is it acceptable and/or safe to weld batwings onto the Ford axle or not??? I have been told that "trimming the spring pads off of the GM axle will weaken it??? If this is indeed the case would welding batwings to the Ford axle result in the same scenerio???
Now the question I have seen several times but not really figured out the answer to though many have been given. Putting the GM spindles on the Ford axle.....I realize there is a bit of work to be doen here in respect to the king pin angle differences, machinging of the king pin bosses, and possible machining of the boss to obtain correct king pin installation. What are the benefits bedises the fact that I have the GM spindles to swapping them onto the Ford axle. I have read that mid to late 70's intermediate brakes from GM vehicles are an option.????
I am very open to suggestions, advice, comments, even those who will tell me to save my money and purchase an after market front end kit will be openly accepted!!!
Thank you all for allowing me the opportunity to be a part of this Forum and the opportunity to learn from those who have been where I am before me.
Muddi1 aka Mike
:bawl: newbie here,
Muddi1 aka Mike
