Welcome to Our Community
Sign Up
Dismiss Notice
Front drum options?
Discussion in 'Brakes' started by Snicklefritz, Aug 21, 2018.
  1. Driver50x
    Driver50x
    Expand Collapse
    Aug 8, 2016
    55
    40
    Gender:
    Male
    Occupation:
    Pilot
    It is a tad on the wide side, but not too bad. I think I need another post or two before I can post pics.
  2. Driver50x
    Driver50x
    Expand Collapse
    Aug 8, 2016
    55
    40
    Gender:
    Male
    Occupation:
    Pilot
    Ford and Chrysler vans from the '60s also had similar solid front axles. Any of them could be made to work.
    Snicklefritz likes this.
  3. Driver50x
    Driver50x
    Expand Collapse
    Aug 8, 2016
    55
    40
    Gender:
    Male
    Occupation:
    Pilot
    Ok, now I can post the pics.....
    Snicklefritz, lincolnuT and Spanky like this.
  4. Spanky
    Expand Collapse
    Jul 29, 2016
    3,086
    2,528
    Gender:
    Male
    Every picture I post comes from my computer files.:)
    Snicklefritz and lincolnuT like this.
  5. HenrysT
    HenrysT
    Expand Collapse
    Mar 12, 2012
    599
    227
    Gender:
    Male
    Occupation:
    Carpenter
    Ted Brown loved the wide axles with looong springs.
    Driver50x and Snicklefritz like this.
  6. Snicklefritz
    Snicklefritz
    Expand Collapse
    Aug 6, 2018
    268
    91
    Gender:
    Male
    i see no "upload a file" button as depicted in your instructional. maybe i don't have enough posts or something.
  7. Snicklefritz
    Snicklefritz
    Expand Collapse
    Aug 6, 2018
    268
    91
    Gender:
    Male
    if you get a chance can you measure kingpin to kingpin?
  8. fluidfloyd
    fluidfloyd
    Expand Collapse
    Dec 29, 2008
    1,092
    291
    Gender:
    Male
    Occupation:
    Toy Builder
    Snicklefritz,
    Absolutely nothing wrong with running drum brakes all the way around. Most all parts are still available at a reasonable cost. The one exception as you have found out is the backing plates. Don't despair as they are out there but it does take a little searching to find some of them. We needed to build front and rear drum brakes that would take 4" wide linings. Also needed the drums to be aluminum with iron linings. These all needed to be based off the 59 era Mercury/Ford 9" brakes that were never a production part. Cast the the aluminum drums. Two separate casting has there was a difference front to rear. Rolled the steel bands and lazer cut the inner rib that the springs attached to. Built a simple welding fixture to hold the band while welding the rib in place. Ordered a cast iron 12' diameter pipe ans sawed if in to 4.5" rings. Machined them and the inside surface of the aluminum drum to a press fit. Then staked the two together. Bought the wheel cylinders, adjusters and springs. Had the linings bonded and riveted in place. Bolted it together just like a family sedan. Found the early backing plates after a short search up in the Midwest. Bought all he had as the fronts were the hardest to find due to spindle changes in later years. So if we could do that then you can surely find what you need. Drum brakes in a lite weight roadster will be more then enough to stop you. And in my opinion they look great painted black behind a chromed wheel. If I ever figure out he photo posting secret handshake I will post a few pictures of those brakes in construction. Good luck with your project and have fun while you can. Getting old ain't for sissies!
    George
    Snicklefritz and Driver50x like this.
  9. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,509
    772
    Gender:
    Male
    Occupation:
    Retired
    Holy crap. 4" wide brake shoes are gigantic. As are the 12" diameter drums. Like used for stopping a loaded semi! But if they work, what the heck.
  10. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    2,534
    1,139
    Gender:
    Male
    Occupation:
    Information Technology (IT) 15yrs, Then Retired
    You only need 10 post before you can include pics. This has been a known problem for a long
    time. It's sporadic and it comes and goes, even for the same person. It's happened to me and then
    one day it was OK again. Ron is not a website guy and it probably costs too much to hire someone
    to fix the problem.
    I am administrator on another forum (same Xenforo software), I might be able to help if I had the
    required permissions.
  11. Snicklefritz
    Snicklefritz
    Expand Collapse
    Aug 6, 2018
    268
    91
    Gender:
    Male
    that there may be my issue. not sure what i have so far but at least it may be that and not just that i'm thick headed. *oh wait a minute... as i type this i see a button for uploading a file. i'll experiment later.
    am i to understand the forum was set up by ron of rpm? i should mention that while i find the situation only a bit frustrating (i've no build thread yet) the overall format is more welcoming than the ntba forum which may just serve as a back up of sorts for the club. thanks for your input sir!
  12. Snicklefritz
    Snicklefritz
    Expand Collapse
    Aug 6, 2018
    268
    91
    Gender:
    Male
    thanks george for the encouragement! i know much of this for me is a learning curve; perseverance, and some leg work are in order too.
    photo posting secret handshake... hahahahaa!!
  13. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,722
    932
    Gender:
    Male
    Occupation:
    Machinist/Welder/Mechanic
    George[/QUOTE]
    Aint no sissies here!!
    am i to understand the forum was set up by ron of rpm? i should mention that while i find the situation only a bit frustrating (i've no build thread yet) the overall format is more welcoming than the ntba forum which may just serve as a back up of sorts for the club. thanks for your input sir![/QUOTE]
    No Ron didn't start the Forum but is a co-owner if I am correct. No he doesn't want to be an IT tech just like the rest of us old guys But some things you just have to learn or go hide under a rock and wait to die.
  14. Driver50x
    Driver50x
    Expand Collapse
    Aug 8, 2016
    55
    40
    Gender:
    Male
    Occupation:
    Pilot
    It's about 54 inches from center to center of the kingpins.
  15. butch27
    butch27
    Expand Collapse
    Nov 5, 2007
    2,493
    188
    Gender:
    Male
    Occupation:
    Retired
    MAN that is wide
  16. Driver50x
    Driver50x
    Expand Collapse
    Aug 8, 2016
    55
    40
    Gender:
    Male
    Occupation:
    Pilot
    How wide is yours Butch?
  17. Driver50x
    Driver50x
    Expand Collapse
    Aug 8, 2016
    55
    40
    Gender:
    Male
    Occupation:
    Pilot
    My rear axle is from a 1979 Chevy Malibu. The front tread width is 5 inches wider than the rear.
  18. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,722
    932
    Gender:
    Male
    Occupation:
    Just put fatter tires on the rear and skinny ones on the front-- or better yet get another axle. Yours would not be the first like that as people used what they had or could afford.
    Driver50x likes this.
  19. Snicklefritz
    Snicklefritz
    Expand Collapse
    Aug 6, 2018
    268
    91
    Gender:
    Male
    thanks.
  20. fluidfloyd
    fluidfloyd
    Expand Collapse
    Dec 29, 2008
    1,092
    291
    Gender:
    Male
    Occupation:
    Toy Builder
    4" Front Brake
    4" Rear Brake
Share This Page
SSL Certificate
