fordsbyjay
I have a thread trying to identify my spindles and I have touched on my brake issues in it but I wanted to start a new thread in the proper section as I have a few more brake questions.
http://www.tbucketeers.com/threads/spindle-identification.14512/
My car has a standard 1" Ford master cyl. I have been having some poor braking issues lately and after the suggestions in the other thread I found my brake fluid to really contaminated ( a rusty color). I pulled the m/cyl out and took it apart for inspection.
All is well so I cleaned it out and will re-install shortly with fresh fluid and flush the brake system. One of my question has to do with the plumbing. The large reservoir is for the front disk brakes and the smaller reservoir is for the drum brakes is it not? Mine is plumbed backwards and I didn't know if the builder just screwed up or if they did it that way on purpose. I have the very small wilwood calipers and didn't know if that had something to do with it.
I figured I would just ask before changing it over to the way I believe it should be.
thanks,
thanks,
