Anyone have experience with using acrylic or other plastic as windshield material? Suggestions, warnings, sources, etc?
Perhaps a shot of the "duck tail" on top?Bill,
Can you show us more of that car?
Judging by the windshield. I'd say this car has more to offer.
Polycabonate is light and not nearly so brittle as glass, so it will absorb impact better. But you have to be really careful with it, because it will scratch up in a heartbeat. And trying to see through scratched polycarbonate at night is like looking through a prism, as soon as light hits it.
Bill,
I uploaded about 100 pictures of that car a while back on my photobucket account.
http://s180.photobuc...ck%20roadsters/
Gerry UK said:Something that thick in polycarb.or plex. would take heat and a large sheet metal brake to
form the lip. In 30 yrs. of forming plastics I've done many shapes and if you have the equip. they are easy to form.
Also,you cannot temper the plastic after. Plex will shatter into pieces when hit, polycarb. while strong will crack
if it is bent back and forth at lot from vibration. or at a bolt hole over time.
You also have to remember that polycarb. will expand 1/4" for every 10" of width in the sun.
plex will expand a little less.
Sorry Gerry, Didn't read everything posted.... Me Bad :spank:
One thing I did notice, that the radiator is not getting as much air into that small opening as needed, overheating and over flow onto the ground, that is embarrassing when it happened to me ONCE! Those noses on the track Ts need a good air scoop at the underside as well, could also have two nice looking scoops on each side?? Hot engines are a beach hehe PS. remember this, air takes the path of least resistance... thats around, rather than through...What a gorgeous T. Loads of great little touches. Especially like the deco clock in the rear view.
Although it would nt be cheap you could get a glass screen done like that (simple bend and some grinding to get the shape of the top edge). They produce the shape and bend and then have it tempered.
Gerry
