Welcome to Our Community
Sign Up
Dismiss Notice
Raising a channeled body
Discussion in 'Bodies' started by Bubbamace, Apr 12, 2020.
  1. Bubbamace
    Bubbamace
    Expand Collapse
    Apr 11, 2020
    8
    2
    Gender:
    Male
    Occupation:
    RETIRED
    Hi everyone. I'm new to the forum and hail from Long Beach, Ca. I don't see many Hot Rod T's out here and need a little advice. I am working on a 27 and its channeled. I have just added doors and thought it would be neat to add a steel trunk lid. I cut out the fiberglass for the lid and found that the rear suspension is too close to the trunk lid to close. I need the depth of the steel trunk lid inner liner versus the depth of the fiberglass body which was very thin. Anyway, its either cut the suspension up and do it over again or raise the body approximately 1.5 inches. Any ideas ? I would sure appreciate them.
  2. HenrysT
    HenrysT
    Expand Collapse
    Mar 12, 2012
    591
    218
    Gender:
    Male
    Occupation:
    Carpenter
    You need at least 10 posts before you can post a pic There's a "Introduction" thread some where on this forum, Sooooo introduce yourself and describe your 27' motor, trans etc.. Pics will be a lot more helpful.
    PS: Welcome to the BEST T-BUCKET FORUM, IMHO
  3. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,804
    1,310
    Gender:
    Male
    Occupation:
    retired.
    Are you using coil over shocks on the rear ? If so , is the bottom coil over mount mounted on top of the axle tube or behind it ( or in front of it ) ?
  4. Spanky
    Expand Collapse
    Jul 29, 2016
    3,022
    2,428
    Gender:
    Male
    Here's Bubbamace's icon, right-side-up . . .
    Bubbamace likes this.
  5. Bubbamace
    Bubbamace
    Expand Collapse
    Apr 11, 2020
    8
    2
    Gender:
    Male
    Occupation:
    RETIRED
    Yes I'm using non-adjustable rear coil overs that are mounted behind the rear axle.
  6. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,804
    1,310
    Gender:
    Male
    Occupation:
    retired.
    Does these pieces of brackets & coil overs resemble your coil over setup ? coil over shocks.jpg weld on lower shock mount.jpg weld on upper shock mounts..jpg I found these photos on ebay.
  7. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,804
    1,310
    Gender:
    Male
    Occupation:
    retired.
    Is your floor already glassed in ?
  8. 409T
    409T
    Expand Collapse
    Moderator
    Staff Member
    Jan 16, 2009
    1,791
    554
    Gender:
    Male
    Occupation:
    Retired
    Those coil overs pictured are adjustable. Can you simply adjust them up whatever you need for clearance? Shimming between the body and frame should work as well.
    Spanky likes this.
  9. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,804
    1,310
    Gender:
    Male
    Occupation:
    retired.
    409t , he says his shocks are non adjustable. I posted the adjustable shocks for an example. He hasn't posted any photos of his actual shocks.
  10. Cristobal Estrada
    Cristobal Estrada
    Expand Collapse
    Apr 29, 2020
    4
    0
    Gender:
    Male
    Occupation:
    Laundry System Planned Work Specialist
    Can you put in spacer with the desire thickness between the body and frame ?
  11. Bubbamace
    Bubbamace
    Expand Collapse
    Apr 11, 2020
    8
    2
    Gender:
    Male
    Occupation:
    RETIRED
    HI Guys. So I've been working the problem and decided to use Adjustable coil overs on the back. I also made some wooden spacers that fit between the body and frame and screwed them in so that they don't move. This solved the problem and I want to thank you for your suggestions. I now have the body high enough to use my steel trunk. Thats a whole nother story. Ha.
  12. Bubbamace
    Bubbamace
    Expand Collapse
    Apr 11, 2020
    8
    2
    Gender:
    Male
    Occupation:
    RETIRED
    By the way, yes the body was already glassed in. I ordered the new adjustable shocks from Speedway. Jared in the tech shop helped me and I bought QA1 coilover/shocks/110 lbs. I hope this also helps with the extremely harsh ride. I couldn't even move the rearend with my weight. Ii'm sorry I didn't get right back with you. I forgot I belong to this Forum. Again, thanks for all the tips. Until next time.
  13. Spanky
    Expand Collapse
    Jul 29, 2016
    3,022
    2,428
    Gender:
    Male
    Post some pics when you can . . . :rolleyes:
  14. Bubbamace
    Bubbamace
    Expand Collapse
    Apr 11, 2020
    8
    2
    Gender:
    Male
    Occupation:
    RETIRED
    I wish I could figure out how to do that, Spanky
  15. choppedtop
    choppedtop
    Expand Collapse
    Jan 10, 2014
    1,924
    631
    Gender:
    Male
    Occupation:
    Retired
    If your not wanting the channel due to sitting to high in the body, just cut the floor out as close to the inside of the body as you can. Raise the body to desire height, and glass the floor back in. You may end up needing to take some off the floor as the body should get a bit smaller toward the bottom as you raise it. Like Spanky said, photos would help, as my suggestions are just what had to do on my roadster a few years ago. Send you photos one of us and we can post them for you. I think you can do that in conversations.
  16. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,716
    922
    Gender:
    Male
    Occupation:
    Machinist/Welder/Mechanic
Share This Page
SSL Certificate
