Restoring A T bucket that sat 10 + years
73570_primary_450px.jpg This connects to their relay. There's a column on the left side of their webpage. Left click on relays. You'll see this when the page opens. Left click on it. HTH .
  • Like
Reactions: Guy
I used used ones. I think they were 30 amp. I always strip them out of cars or trucks whenever I scrap them, or anytime I go to the bone yard I grab a pocket full of fuses, relays, etc... saves a trip to the store, lol. I just use female spade connectors to wire them. The closer to the headlights, the better. The wire is a resistor and causes a voltage drop. I installed new hid bulbs in my dump truck and they weren’t very bright, plus they would overheat the headlight switch and go out randomly. After re wiring them with relays and a shorter, heavier battery lead, problem solved and very bright.
  • Like
Reactions: Guy
As far as your brakes go, I think the star wheel on the adjuster should be below the coil of the spring. That's what keeps the adjuster from backing off. Kind of locks it in place. That's the way I've been doing it for many years. Maybe someone else can chime in on that.
Bill
"To switching means " , goes to your ignition switch ( power when ON position ).
No,
That means the hi-Lo switch that sends a +12V "signal" to the relay, that pulls in the coil which transfers the connection between the +12V from the batter that by default goes to one of the lamp connections to the other lamp connection.
When there's no "control signal", the +12V from the headlight's switch goes to the low beam lamp wire thru the normally closed relay contacts.
When the relay is energized, the +12V is then connected to the Hi beam lamps' wire.
Using a single relay to switch between hi and lo beams still requires a main switch for the headlight.
If you used 2 relays. one to turn on hi and one for lo, you could eliminate the main headlight switch, but you'd need a three position toggle switch to control the 2 relays . . . Hi---OFF---LO
  • Like
Reactions: Guy
Breaks are all set finally, what a pain and it's so hot out to be testing had to be something on both sets of shoes now both drums are cleaned up and both wheels on the front have new shoes working very nice . Going to order that relay set up from Delcity should work out ok I hope , oh this morning when I was going to talk my car out one break light didn't work took it apart doesn't have a spring under the socket had a rubber garment, so back to the parts store to but a pig tail and spring now that works again, I have come to realize theses cars are never DONE it's an ongoing thing LOL
Bill
This is the way it was when I took it apart the first time I replaced it according to the Chevy book
The long part of the spring goes against the adjuster , or I guess you could call it the long thin part the hooks to the shoe
I took a look on google and the brake adjuster and spring placement are shown both ways; with the coil of the spring over the star wheel and with the coil of the spring away from the star wheel. Maybe either way is correct. I've always put the coil of the spring over the star wheel. It seems to help keep the adjuster from backing off.
images
Depending on when it was made, (drum brakes in general) it may be designed to have a adjuster in the mix that acts as a ratchet and tightens as you back up... those typically had a spring with a shank that avoided the star wheel. The brakes will back off without something to resist star wheel rotation.
images
thats not the spring i have mine has a long thin part
View attachment 16640 This connects to their relay. There's a column on the left side of their webpage. Left click on relays. You'll see this when the page opens. Left click on it. HTH .
the problem with the lights was i wired it the same way who ever did it before and the ground was wrong , now lets see if i can get though one day without fixing more things that they had done . I went out for a short ride and got rained on but not too bad
