seat springs
akitagandy
I know you cut 2 holes and use webbing, I don't have any webbing but I do have some S springs out of a sofa do you think this would work
Yes those will work. If you want to use webbing, go to Wal-mart. I think I paid a buck for a yard there. It's much easier to work with than the springs. While your there get enough burlap to cover the webbing so it dosent chew up your foam. Check with your local upholstery shop for hi-density foam. you can cut it with an electric carving knife and shape it with a 3'' sanding disc on your diegrinder.
