tnoftsger
Alright brake experts, can't seem to get a firm pedal.
Napa 36300 master cylinder, 3/4" bore, approximately 1" of stroke before it bottoms out
5.5:1 pedal ratio, no binding and getting full stroke
stock 1966 mustang drum brakes 10" X 1.75" shoes
GM intermediate disk brakes on front 2.934" piston
Steel line run from master cylinder to front of frame, stainless steel braided hose to calipers.
Steel line run from master cylinder to rear kick-up, stainless steel braided hose to tee on rear end.
bench bled the master cylinder with plugs first and then with lines run from the outlet back into the resevoirs. Pump and then wait 15-30 seconds, pump again wait, etc.
bled the lines by pumping and hold, release bleeder futherest from the master, then move to opposite wheel.
with the one port plugged and rear brakes connected, i get a firm pedal, connect the disk brake system and get soft spongy pedal.
Switch the lines on the ports on the master cylinder, no help.
The engineer in me had to do the math:
3/4" master bore times the 1" stoke you get (pi*r^2*stoke) nets 0.44 cubic inches of volume.
the 0.44 cubic inches of volume translated to the 2.934 inch caliper piston (0.44/pi*r^2) nets 0.065 inches of movement, divided by the 2 caliper is 0.03 inches of piston travel.
I know that the pads ride very close to the rotor, but it seems that i don't have enough volume per pump of the pedal to compress the pads solidly before i run out of stoke.
whatta ya think?
Thanks in advance
Tom
whatta ya think?
Thanks in advance
Tom
