Welcome to Our Community
Sign Up
Dismiss Notice
Speedway Chevy Spindles
Discussion in 'Suspension' started by Snicklefritz, Feb 23, 2022.
  1. Snicklefritz
    Snicklefritz
    Expand Collapse
    Aug 6, 2018
    268
    91
    Gender:
    Male
    Hey all, I'm asking around because I asked Speedway Motors and I'm still unsure. I'm looking at using their '49 to '54 Chevy spindles and their advertising says the geometry has been changed to complement radial tires. Yet I'm not sure how... change in camber? Also, not sure if this would cause premature or uneven wear on the bias-plies I plan on using.
    Speedway 1949-1954 Chevy Car Modified Spindles w/ King Pins
  2. Spanky
    Expand Collapse
    Jul 29, 2016
    3,022
    2,428
    Gender:
    Male
    I am using those on mine, but I do have radial tires. What did Speedway tell you?
    Snicklefritz likes this.
  3. Wyo George
    Wyo George
    Expand Collapse
    Dec 17, 2014
    54
    18
    Gender:
    Male
    I’m not sure what they did with those, but generally speaking a radial wants a bit more positive caster and a bit less negative camber than bias ply and since camber angle is built in with king pins I’m guessing that’s what they changed. Caster is also built in to a degree, but it’s easily adjusted so they may or may not have changed it in the hub.
    I know, not a real answer, but possibly a point in the right direction. As to issues running them with bias tires, I doubt it, but I’ve long since quit running bias tires so I’m not a good person to answer that question. My experience comes from changing 50’s and 60’s cars to radials and adjusting alignment accordingly.
  4. Snicklefritz
    Snicklefritz
    Expand Collapse
    Aug 6, 2018
    268
    91
    Gender:
    Male
    i asked to clarify the blurb in the product description and they seemed to not be able to give specifics. i asked too if i would run into any problems and they said i shouldn't. they may be right but i don't want to have wear and drivability issues after the fact. just out of plain stubbornness to solve a mystery i might keep on them until i get details; figuring i could help others as well.
    what are you using for brakes?
  5. Snicklefritz
    Snicklefritz
    Expand Collapse
    Aug 6, 2018
    268
    91
    Gender:
    Male
    actually you're helping with pieces of the puzzle. if you're onto something with your points then it seems i don't have to necessarily worry about tire wear or safety issues. if i'm right more positive caster, if anything, will give greater higher speed stability. the camber issue has me wondering a bit still.
    Wyo George likes this.
  6. Spanky
    Expand Collapse
    Jul 29, 2016
    3,022
    2,428
    Gender:
    Male
    I am using GM 'metric' calipers with Mustang II rotors purchased from Speedway. They seem to work just fine, in combo with the stock rear drums on my GM 10 bolt rear end.
    Snicklefritz and lincolnuT like this.
  7. Snicklefritz
    Snicklefritz
    Expand Collapse
    Aug 6, 2018
    268
    91
    Gender:
    Male
    i figure with a car that weighs around (or less) what a mustang 2 or pinto does these brakes are plenty good. since i'm going with a 60s look this set up is less of an authenticity sin than the fancy fad-t type brakes.
    i'm begining to feel a bit more at ease about things using bias-ply tires and this modified spindle with the feedback i'm getting. i know some cars suffer "the shake" and want to make sure everything is engineered right.
    thanks for the inspiring photo!
    Spanky likes this.
  8. Wyo George
    Wyo George
    Expand Collapse
    Dec 17, 2014
    54
    18
    Gender:
    Male
    It actually helps prevent wandering!
    (sorry, can’t resist a dad joke type pun)
  9. Snicklefritz
    Snicklefritz
    Expand Collapse
    Aug 6, 2018
    268
    91
    Gender:
    Male
    it's ok. in my family everyone made bad puns.
    lincolnuT and Wyo George like this.
  10. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,214
    1,182
    Gender:
    Male
    Occupation:
    Retired
    I think Coker tire offers radial tires with bias type tread. May be an option if you have problems.
  11. Snicklefritz
    Snicklefritz
    Expand Collapse
    Aug 6, 2018
    268
    91
    Gender:
    Male
    that crossed my mind. i did a quick look to see what they might have but i gotta spend more time on their site, and check out other suppliers too to see what's available.
  12. Spanky
    Expand Collapse
    Jul 29, 2016
    3,022
    2,428
    Gender:
    Male
    Just curious, why are you planning to use bias ply tires?
  13. Snicklefritz
    Snicklefritz
    Expand Collapse
    Aug 6, 2018
    268
    91
    Gender:
    Male
    i'm going with bias plies in keeping with the look which is why i'm using leaf springs and all the other details; the brakes are a bit of a practical deviation that hopefully won't be too much of a aesthetic sin. my favorite era of t-bucket is around the mid sixties.
    Spanky likes this.
Share This Page
SSL Certificate
