Jim B
I know it is a NEW starter, but it sounds as if it is bad. Replace/TEST and replace battery cables and get a braided ground cable to run from starter bolt to frame. I have seen the starter ground through the shifter cable because it (starter) wasn't properly grounded. Things tend to heat up when too small of cable is used and it will melt/ burn down all associated with it.
Grounding the starter sounds pretty easy and it sure can't hurt. I might try another starter just in case. If they are both good, then some lucky fellow forum member can pick up a almost new starter in the classified section.
In fact, when I get further along, I am going to inventory all my duplicate stuff and put all of it up for sale.
