Hey Leo, have you hooked up with the Springfield bunch? Get ahold of Al "23Tzer" Carpenter at sugarloaf_1998@yahoo.com and have him put you on the e-mail list. They have some sort of T-bucket or hot rod event almost every month, plus there is a lot of hot rod building expertise in that group.
Leo,
Looks great, Where wre you hiding the body?....Ron(ruggs)
Looks great perfection takes time. Not to be critical but I was looking at your front spring from this bad old eye angle it looks like spring mount could contact axle when fully loaded.
Engine and tranny in fuel line run . Wedged a 2x4 against brake to leave overnight to check for leaks had a couple. Been snugging fittings last 2 day finally have none.Next the driveshaft here's two pictures.
Your right it will any suggestions on how to fix?
Thanks guy's pulled bolts and plate off bottom stuck bolts back though top holes and determined square u bolts will clear axle by a half an inch.
