The rebuild of the YeloT
lincolnuT
Before I started.........
After some parts were removed........
JUst how much are you going to change? Don't muck up a neeto car, man!
Mike,
I need to remount the body after many years of New Mexico roads. I will redo the engine mounts, I intend to replace the trunk with a 20 inch bed along with a new gas tank. The bed will require a diffrent Top and mounts.
The main thing is the body mounting points because you can feel to body move when you get in the right movement and I just think it will be much safer after some upgrades. The car is about 12 years old and I will just feel better........Once you take the body off the frame you know the old story about, while I am doing this I just as well do this and so it goes..........
Mike
New Motor mounts being machined........
LincolnuT: Who's frame is that? Is it a Dragmaster?
Looking good so far...the bed will definitely give your ride a different look.
Ben, I don't know who built the frame. It was under there before I bought the car. It looks like DOM tubing when I cut of the back part. I think the car will really look different for sure............
Mike
Extending the bed by 4 inches..............
Needs some work now for sure...............
Looks a little naked now............I will start putting it back together soon.......
Dang Mike that is gonna be cool !
If you have any questions go ahead I have down this road make sure you cut behind the door outline.
Thanks Fred, I am ready to see some photos of your build?
Putz, I have decided to only extend the bed for more room to carry the wife's stuff, lol.......I have that done and now I am getting ready to mount it on the car but I need to set the body back on the frame for some mesurments.....................
Mike
Unless I can convince the wife that it will be cool without fenders then they will be reinstalled............
Mike
Ya got me convinced Mike!!
Some glassing to reinforce the bed........
Mike
What is going to happen to the old deck?
Lookin' good, Mike! I can't wait to see the finished product!
Mike
Mike i guess it will hang on the wall in the shop. I really had not thought about what to do with it. You got some ideas?
Mike
Before I started running new lines. The gas line was done here......
New Trans Cooler and some new lines to it........Also some much improved body tabs......
Mike
