When you are developing a new combination, the camshaft, compression ratio, the intake manifold, the torque converter and the weight of the vehicle are all joined at the hip. Read that line until you have it memorized, then write it on the blackboard 500 times.
Light cars do not want loose converters, unless the engine design is such that a loose converter is necessary to get the motor up into an RPM range where it is happy. And in order to reach that RPM range, a trans brake might become necessary, because vehicle weight will not provide enough resistance to make it happen. Read what Screaming Metal had to say.
If you do not already have a stock converter, look at the
TCI Street Rodder Converter. In a T, it will likely be 250-300 RPM looser than a stock converter and that's going to be plenty for such a light car.
I realize the torque converter manufacturers need some way to gauge and compare converter stall speeds, but go back and read that sentence you were writing on the blackboard. If someone hands me a 3,000 RPM stall-speed converter, my question (and the *only* important question, BTW) is to ask what combination provided that slip speed. A very torquey 454 in an Impala? A mild street 305 in a Camaro? A mild 383 in a T-Bucket? Because (get ready, because there is going to be a quiz) those vehicles are all as different as night and day and they are not going to be able to achieve the same stall speeds. Pull that 454 out of the Impala and put it in your T-Bucket and the very same converter is not going to give you the same stall-speed as it did in the heavier car. Because the T doesn't have enough vehicle weight to pin the car to the ground. Yes, I've had people buy loose converters and then come back to gripe about the converter not stalling as high as it was advertised. Yeppers, and that is because their motors wouldn't make enough torque to pull a sick whore off a toilet seat.
If by "Thumpper cam", you are referring to the Comp Cams Thumpr[sup]TM[/sup] series of cams, that isn't much to be concerned with. Anyone who has been in the high performance aftermarket for 7 minutes has already talked to at least 3 customers who want a 3/4 cam for their car. We took an old cam that had some lobe damage and knocked the front four lobes off. I kept it under the counter at the speed shop and when someone asked me for a 3/4 cam, I would toss it up on the counter. There are only three camshaft profiles available - the RV cam, the 3/4 cam and the full-race cam. Screaming Metal, am I lyin' or dyin'? And no, I'm not joking. People would walk into the shop and base camshaft selection on, "gimme the biggest cam I can get to use with my stock torque converter." :suicide: And after reading that line, I bet there are going to be 100 people who are suddenly taking great interest in their shoelaces. Some people simply are not interested in building power in a particular RPM range, they just want a rough idle. So, Comp Cams decided to grind some cams to fill that market.
A Thumpr[sup]TM[/sup] cam in a 383 is going to be tamed considerably by the engine displacement. That same cam in a 283 would be a temperamental pig, but your inches will settle it right down. To a point where you will ultimately be happy you ended up with a dual-plane intake, because it's going to work a lot better than the single-plane would have.
You get all those sentences written yet? Good, now erase them and take this wet sponge and wash the blackboard. Because you're going to write them again. Camshafts play a hand in cylinder pressures, as do compression ratios. Camshafts are designed to be most effective in certain RPM ranges, as are intake manifolds. Engines want to be happy, so it is necessary to find a torque converter that will allow your vehicle's weight to make the motor happy. Then you get to find a tire height and rear gear ratio that will accomplish the same. Think about all of this, the next time the guy at the speed shop starts asking you questions before just tossing his own 3/4 cam on the counter.
And bear in mind that it is deadly simple to identify power loss in a car. Loss shows up everywhere, in the form of heat energy. You take a given quantity of gasoline, try to atomize it in a stream of air, squeeze it as tight as you can and set a match to it, to make as much heat energy as you can make. Then you move the majority of all that heat energy you worked so hard to create into the exhaust system and into the cooling system. Ever notice that torque converter manufacturers warn customers to install aftermarket trans coolers? That is because a loose converter will transfer more, yeah, you guessed it, heat energy into the fluid. The next time you drive your car, watch the temperature gauge rising as you drive. The energy you are using to heat up that 4 gallons of coolant is energy you are not transferring to the ground. When someone comes along with a car that has no radiator, you'll know that company has found a way to make their engine design more efficient, because there is no longer any heat energy being wasted to warm coolant.
