fletcherson
First, I am sorry to hear about Mike. May he rest in peace! I have been away for a while, just rediscovered the site. I tried to access it before and it seemed to be gone. I am getting back to the T after being dry docked for a while.
I have a vega box with a RPM under frame bracket and am trying to decide the best location. It is a traditional push, pull steer. The happy spot seems to be right at the oil filter spot on a bbc, just ahead of the bell housing (standard) and seems to clear without too much modification. Issue is the hairpin mount occupies the same spot. I can devise a workaround, but this is the first time I have done this particular mod. Any wisdom or pics? I prefer not to do it twice if possible. Also, I plan on using a telescoping, tilt column from a caddi and it will require shortening. Any tips on which joints to use? Weld on, etc? I do not have a machine shop at my immediate disposal, so resplining is out. I could cut a section out and weld the shaft to retain the spline, etc...
