Wow, my wheelbase is already 112", the body on mine must be much longer. The proportions on your are perfect.
If you go to the Lounge section & click on "how to post pics for the computer illiterate" thread , about halfway thru you'll see a white "T" w/a turtledeck , that should give you a sense of proportion . If I could I'd move the pic's , unfortunatley , me & "puter's don't get along that well . BTW , you still in peoria ?
I've been noticing a little quirkiness with posting here.Pics are back? wah?![]()
Yes, I don't want to dust bath everything at a cruise-in or car show if I happen to go, lol.You may want to reconsider putting turn downs unless you plan on only driving on well paved roads as they will kick up a lot of dust. But if you rotate them ninety degrees and have them turn outward there should be no problem.
Yessir, I did ground the filler flange. There was a label on the cell, or I may not have known that honestly.If you dont know this already, when using a plastic tank like that is imperitive that you install a ground strap from the fill cap flange to the frame. Plastic tanks like this can generate static elec. and wouldnt want you or anybody have it go off when filling, In fact it is mandated in the NHRA rule book that all plastic tanks be grounded to the frame or you dont run.
