Hi guys,
I'm busy rebuilding the "bargain basement" '27 I bought. I looked at the engine mounts and found that the engine is hard mounted to the frame. The side mounts are welded to the frame rails.
Since my garage tools are rather limited, I'm thinking about using Speedways old style sbc front mount and cushions with some fabbed, bolt-on frame brackets. That way I can lift the engine enough to install the front mount and cut away the welded mounts. Other than aesthetics, is there any reason I shouldn't do it this way.
You folks have already helped me immensely on straightening out the rear suspension on my "T"
Thanks in advance,
olguy
Thanks in advance,
olguy
