askiles
Okay, so I have my car ALMOST done and of course I run into a problem. One I can't see to get around. I have a 351C 2V engine from a 1975 Ranchero, Edelbrock 2V 4 Barrel intake manifold, with a Summit Racing 600CFM Street/Strip carburetor. At this point the timing sounds correct or really close when it runs, I just cannot keep it running. Sometimes it will run longer than others. It runs fine, runs fine, then all of a sudden will just shut off. I am guessing some sort of fuel problem, but if you look at the primary sight glass, it always stays half full. I checked the power to the coil, and it seems to be getting 12V consistently. Can someone please start throwing some ideas out there?? Thanks!!!
