Spaceman
I'm new at dealing with older car items
so I figure I'll ask the experts. While looking around the net at spindles I've come across both cast and forge types. Based on what you have learned from building yours which type would you recommend, whish you had used, or are they basically the same? I'm not trying to start a poll, I just want to be better informed before I buy a set. I am planning on using a disc brake set up if that has any bearing. Thanx in advance. Spaceman
