37-41 ford spindles
OOPS my bad i should have known GAB is always on the ball
Another idea is to use the Chassis Enginerring (Westbranch, Iowa) forged spindles - the ones that are made to accept GM rotors, no adaptors required.
We have all of that already made up and on the shelf. These pictured use the GM metric caliper. We have the others also.
Guys and Gals
what about rotor bearings u got any numbers or reference for the old ford spindle
Ken
If your using gm rotors the the bearings are A2 outer bearing and A17 for the inner bearing and the seal is the 1972 camaro rotor seal.I know this is lat post but i had looked here before to try and find it and never did,so i thought id share a little info.Hope this helps other out.Got mine from O*&^%$#s Auto Parts
Didnt know if i could use the name here w/o getting into trouble?
Vince
