Ok, So I desided to get off of my butt and put my feelers on for a well priced BB 454. I dont have a bucket yet, But I can always get one once the motor is done. I want to know what you all think. Im trying to get a chevy BB 454. I would like to have it done .40 over with a copression ratio of 7.5:1-8:1. I would like the compression at that so I can run a descent boost on pump gas with a Weiand 6/71 Blower. I would also like to have the possibility of maybe a 200shot. The NOS is not set in stone, But it would be nice to have the option. I would most likely use a holley cam with a lift of .555/.571 to give it that old Hot Rod rough idle. Also the 7.5:1 will allow for 10lbs of boost, as the 8:1 will allow for 6 lbs of boost on pump gas per Weiand specs. The carb set up will be dual 750s. Heads From what I hear are fine at stock with a valve Job... Please correct me if this set up sounds wrong, or if there is a better set up that would work better. It will be a heavily used street car that sees shows, and the strip only every so often. Also, Will I need a windage tray . I am probably going to go with a Milodon, or morosso over sized oil pan...I can use all the advice I can get, since I have not build my own motor since the 80s. And I have never built my own blower set up...
Thank you all for the help, and please excuse the type Os. Im just very excited.
Mike
Mike
