Bucketman
I agree with Dave about the aluminum heads. It just depends on your goals and what the iron heads actually need. Still the rockers and girdles are well worth the price if you can use them and their condition. The studs and push rod guide plates are likely stock. Those old iron heads will produce plenty of power for a street thumper as long as you keep the compression to a reasonable ratio +-9.5:1 or less on pump gas, depending on cam and timing control. I personally like using period correct components on stuff from a nostalgic perspective, Old school. I wouldn't put a ton into them though.
What heads would you recommend? A thousand dollars a pair is the top of my spending limit. sbc 350, with 600cfm Holley, will match cam to heads.
