JetMech727
JetMech727, if you dont mind I have a few questions. What grommet kit did you use for the wires? What did you do to the ends of the braided line that covers the headlight wires? And how did you make the braided line that covers the throttle cable? I appreciate any help that is offered. Thank you.
Hi Kyle, hope this helps. No grommet kit was used. My local small town Ace Hardware has an excellent selection of grommets I was able to pick and choose from. Heat shrink tube was used on the ends of the braid to tidy them up. Throttle cable is just a standard Lokar set up. I usually drill the frame grommet holes a couple sizes over to allow the grommet a little wiggle room. This allows easy grommet insertion after wires are pulled through it and keeps it from getting pinched by tight wiring causing them to get cut and fail. And hole deburr inside & out is a must.
