Chris, what type of distributer do you have? Point style - yes, you need the resister to protect the points from excessive voltage that will cause point burning. HEI distributers require the full 14.5 volts (?) to function. Actually, 12 volts are fine, anything more from the charging system is gravy.I was told I shoud use a ballast resistor by a friend. So I bought one.
When I put it in the car wont start. Without it car starts fine.
any thoughts on this?
If you have a resister installed then you should have 6.5 volts to dist. I don't think the car will start that way but will run. The 12.0 volts when starting is from the starter solenoid.I'm using points.
Just not sure why the car won't start with the resistor installed.
Advantages - one wire, 12.0 volts to dist., self contained, easily modified for more oomph (voltage wise)Maybe I should just change to a HEI.
What are the advantages and disadvantages of an HEI?
OK maybe I have the wrong start.
Mine don't have the extra place for a wire to go to the coil. Like this image.
[attachment=4102:tt4a.gif]
Wow, you are moving right along, I was going to say get a 1970 solenoid for your starter and wire it up. But this is good. Check to make sure advance weights are free and lubricated. You can modify later.I got an HEI Dist.
$40. Off craigslist. Stock one from a chevy.
Installed it, Now car seems to run and sound a bit better. Just need to get the timing.![]()
Did you ever figure out why the front end was so stiff?
John
Don't want to pin you down, but I might be available if you need help for the final phase. Do you have a time frame? I know you have to lift it over that side fence.
John
