I'm building a C cab and due to space restrictions, I have to mount the battery towards the back. What gauge positive cable would I need to use for a 10' run. Thanks.
I've always used 1/0 welding cable in all my regular cars. It's pretty heavy and have never had a problem with it. I don't see why the #2 wire Jim mentioned wouldn't work however.
I also prefer these type of cable ends. http://www.summitracing.com/oh/parts/mor-74170/overview/
I have used this style of end in both side and top mount. I have them on everything but the bolts tend to come loose and require the occasional maintenance.
http://www.summitracing.com/oh/parts/pco-0879g/overview/
Then of course you have the standard solder type connector for the eyelet end available in copper at your welding store or parts store.
One thing I would do is call as many places as possible for pricing. I find prices really varied in my town.
I would just add that you will want to make sure to use the same size cable for your ground, as well. I see a lot of guys who try to run small ground cables and then wonder why they have problems.
Also make sure to ground the engine to the frame along with the negative terminal of the battery to the frame. Poor grounds are the single most problems in an automotive electrical system.
All great info! I see alot of folks using those old cheapo, $1.99 universal battery clamps on $25,000 show rigs. 1st or 2nd time you have to remove your battery, the gap has closed up , if you don't use alot of caution and use your battery post terminal pullers everytime, etc.
Do yourself a favor and go out and buy the Military battery post clamps. Its a big thick clamp, and has a 5/16 or 3/8's bolt that attached the battery cable to the battery post. Want to undo the cable, take the nut off.....leave the battery clamp on.
Alot less wear and tear, looks alot better and is heavy built. You can even use 3 or 4 large cables with the brass lugs with those battery terminals....
http://www.premierpowerwelder.com/terminals/terminals.html
Well, the ideal thing would be to use #2 lugs, a box of them is less than $6. But, if you want to use #2 lugs on 2/0 cable....you can trim it down.If one uses 2/0 cable, how do you get the wire in the 1-2 size terminal? Trim the wire until it fits?
What I do to adapt a #2 to a 2/0 is I peel the insulation back, then I solder the cables end up solid. The I can use my belt sander to achieve a tight fit to the #2 copper lug. Then, I solder it to the soldered end of the cable....
