Need some expert advice. I'm mounting a Spirit body to a Spirit frame. Spirit uses mud flap material as a cushion between the two. Is that really necessary? Does it really do any good as opposed to not using any material at all? What do you guys do?
We use a double sided tape from NAPA, it is to go between a camper shell and a pickup truck bed. Stops the squeaks is all it does.
I mount mine as solid as I can get it, because with the use of windshield brace rods, you do not want any body movement at all...![]()
You are right about that, I have plywood floors and they don't squeak at all, at least what I hear myself, hehe but the wood does compress over time and need re-tightening now and then, a large (thick, and over 2" in OD) top flat washer helps greatly with this loosening problem, plus a tight fitting (to the hole in the wood) tube that the bolt also fits snug through, just a bit shorter than the wood, helps with keeping the hole from wallowing out, over time...I like the idea of the two sided tape, but if it's a plywood floor mounting to the frame how's that going to squeak?
Actually, the camper mounting tape that I used only has adhesive on one side so that when applied to the frame, the body can be removed without tearing up the tape.
