Brake pedal...
Track-T
Since my master cyl. is mounted on the firewall I had to make up a hanging pedal assm. that fit.
I took 3 pieces of 3/16" alum. plate and cut the holes in the side parts then screwed the parts together.
Looks good. I too have MC mounted on firewall. Be sure to reinforce your firewall so that it doesn't flex during braking. I used 1 x 1 steel angles mounted vertical on each side of pedal box.
I made my own firewall, It is 2 pieces of mdf glassed on both sides.
the pedal mount is 1/2" alum. plate with another 1/4" plate on the engine side.
Track-T after looking at your steering wheel post it looks like your m/c is on the out side of the firewall, or am I missing something. I am looking at doing like that because no matter what I do my brakes have to be pumped once to work right. (I do have p/r valves in the system)
Yep, On the firewall....
