ellis8500
Keep in mind there is not much of a load on the shock mounts unless the shock bottoms out. The shocks retract and extend in operation; the only load is the resistance of the shock itself. I have two 1/4-20 grade 8 bolts vertical, one horizontal. Each bolt is good for a 4750 lb tensile load so two provide 9,500 lbs tensile strength per side. Total both sides 19,000 lb tensile strength. As I said before, you can lift the car with those mounts.
If you need custom mounts, draw them and send to RPM for a quote. His prices are unbelievably reasonable and his service is the best. If you need some CAD work done, send me a sketch.
Hey 2old2 fast...my youngest brother lives in Ottawa. We grew up in Aurora.
