cooter
The body is narrow at firewall. Reason i was hugging the block so tight. If i come outward it looks like shaft will come through firewall right in corner of firewall and cowelThat mount looks like the angle will be too steep for that length of cowl, maybe trim the tab down a bit at the rear of the bracket and that may allow the box to go forward enough for the set screw to clear the block. If that is not enough trim the mount to allow the box to move outward.
