Explain more?Cooter
I know its kinda late in your build to bring this up but I must.
I noticed that in a lot of your pics of the frame it does not look like you did much weld prep on the tubing or the flat stock.
Its very important that you remove all mill scale prior to fit up and welding. You will find that your beads will lay flatter and burn in better and you will get a sound weld.This is realy important with the mig process, stick electrode is more forgiving.
keep up the good work.
