right front engine frame mount is 1/8" farther forward than left front? im tired of cross measureing tryin to find out why. maybe engine cast wrong, engine mount holes different who knows, she just gonna be 1/8/" off. least I know it will line up when I go back. im ready to burn this thing in if everyone thinks this is acceptable. I think so.
Thats rightIt'll work just fine!! U-joints will take up for the slack in the difference. Can't you remember when Chevy used to offset the I-6 engines in Novas?
If you can live w/it , it'll never hurt a thing .... me , I'd drive myself to the brink of insanity figuring out what's wrong !!
Yes. But i used a 10" stretch body and added 10" to frame.Cooter did you use CCR plans as to how far back to place your motor mounts.
I think so. Ccr doesYes ok I used the same motor mounts, but I did not tilt mine back. Wonder if I should ?
Thats right.fordnut...You should set the top of the motor mounting pad parallel or equal in angle the same as the crank interline so as not to twist the isolator bushing.
