What kind of ply wood did you use? If you use a good exterior grade it should not need all that glass work. It won't be exposed to constant moisture. You might get caught in some rain, maybe once or twice a year.Me personally, I say glass it.
I used cabinet grade I guess. It's not exterior. Guy commented on my ntba post on Facebook about plywood boats being glassed on outside only wich got me thinking. Yes, it's easier on my part to just glass the edge to tie the floor and body. You know how much moisture this car will get. Is it better to dry out, or dry rot is a comment I just read on a boat forum discussing this.What kind of ply wood did you use? If you use a good exterior grade it should not need all that glass work. It won't be exposed to constant moisture. You might get caught in some rain, maybe once or twice a year.
I think the whole reason for the glass is for strength. The wood is a substrate, so even if it did decay in twenty years, the floor will still be strong from the glass. In boats, they glass both sides of the transom. If they dont glass both sides of the floor, I suspect it's due to ease or expence, and they use premium marine grade plywood that is very rot resistant anyways. The floors rot first in boats, then the transom, from my experience. I am not a boat professional, but have repaired several over the years and the floors are normally rotten. I wouldn't worry about it personally. I am glassing everything, no exposed wood.I love my AC in hot weather and heat when it's snowing outside.. There is no wrong way or right way I guess on the floor. I have found that for the most part, kicking ideas like this around among fellow builders is a good idea and usually saves me heartache.
I like all the pics and advice I can get. We all trying to build long lasting T's.
I, too, have a "climate controlled" garage. My garage is connected to the house and the system in the house has vents in the garage keeping it the same temperature as the house. Living in Florida you really need air conditioning in your garage if you want to do anything. As for heat, I REALLY hate the cold weather so the heat is great also. I always say that I don't like any temperature that is below my age and I'm 74. LOLI love my AC in hot weather and heat when it's snowing outside.. There is no wrong way or right way I guess on the floor. I have found that for the most part, kicking ideas like this around among fellow builders is a good idea and usually saves me heartache.
Straight glass?
