Learn something new every day. All I new was I didn't want to go any farther than I did. Thanks for the tip.You really don't want to create a " hard" line with tape , you'll end up fighting that later , much better to featheredge your filler / primer line, hard lines usually end up telegraphing through the paint no matter how careful you are .
What the crap did you say?? I probably just paint it with a rollerIMO that's a lot of work , I'm really old school , rough cut with 36 , , / smooth w/ 80 , then high build 2k primer , usually ,K-36, block w 400 , 2 more coats of primer then block w/ 600 , single stage , it's time for paint , 2stage , wet block ,w/1000 before paint ... my favorite block is a 10" .then. 2x4 hard blocks,.
All depends on what you want for an end result ..What the crap did you say?? I probably just paint it with a roller
"maybe just a bit of overkill ?!?!?way too much info all at once , reminds me of " dazzling with brilliance," vs " baffling with bull shit," I'm not sure which is worse ..."IMO that's a lot of work , I'm really old school , rough cut with 36 , , / smooth w/ 80 , then high build 2k primer , usually ,K-36, block w 400 , 2 more coats of primer then block w/ 600 , single stage , it's time for paint , 2stage , wet block ,w/1000 before paint ... my favorite block is a 10" .then. 2x4 hard blocks,.
Any comparison to the 2 1/2 lines I wrote to that x pages long epistle that your referring to is completely unwarranted...."maybe just a bit of overkill ?!?!?way too much info all at once , reminds me of " dazzling with brilliance," vs " baffling with bull shit," I'm not sure which is worse ..."
read that somewhere on this forum and thought it sounded very appropriate. : )
Air plane =flat file = air file ???That's the way I would do it. Only difference is I like to use an air plane.
