Indycars
I wanted to take this conversation to the correct forum, but below is a link to some more info.
Short Notice - Cruise Lake Texoma
Got the damaged pan off this yesterday, here is another look at it while it's off.
I have a problem with the new pan, it hits the oil pump before it can go forward enough to
align with the bolts holes in the block. I don't have the pickup tube installed, so it hitting the
pump body. It needs to go forward another 1/8" to let the bolt holes align with the block.
Note the difference in corners #1 and #2. Number 2 cuts the corner off more than corner #1.
You can see where the oil pump is putting marks on the pan wall when I try to push the
pan forward.
pan forward.
