rubicon
Thanks good info. Will check it tomorrow.Check the voltage at the pump. Flow volume drops drastically with a reduced voltage.
Are you using a relay with a switch or a switch only to provide voltage to the pump?
I had a electric fuel pump failure in August 2021 and I couldn't find any replacement parts then. Quickfuel sells an end bell that looks like it should work but will not. For more info check out my thread on this situation.I do think parts are available to service them.
Not trying to talk down or criticize your choice rbsWelder. Just didn't want others to think that would work for everyone.I have had several Holley fuel pump failures. I moved to a K&N from Advanced Auto, with a lifetime warranty and have not had a problem!
Good point. A sticky or corroded relay could cause intermittent issues.Check the voltage at the pump. Flow volume drops drastically with a reduced voltage.
