Electronic Distributor hook up
KPoole9008
I have a distributor with an electric module inside [no points]. It has two wires coming from it, one is black and one is red. I need to know where the wires hookup. Thanks
Do you know what kind of distributor or a pic would help. Mallory or Hei or Pertronix These are a few
Look on the critter somewhere and find a Name and a number and then do a search at the MFG'ers....you have a power feed in,: then you have your coil wire, and usually a tach feed coming out.
Don't try and just hook them up willy-nilly, you might fry something....
I finally found a name on it [bottom side of the cap] and called Procomp. They gave me the info I needed. Thanks guys.
