dustytrails
heres a list of my problems so far only about 30 miles on new rebuild every thing is new carbs,intake,cam,rings pistons,distrubitor,rough idle,stall when stepping on gas,popping on both sides at high idle,oil on plugs and inside headers,after driveing a few miles i get oil around distrubitor and rear main leaking,every thing has been checked,timeing right plug wires in right place,no pcv valve,useing 2 breathers ,valve lifters bleed down as you watch,i know they bleed down but should it be that fast
