as for the radiator and water question. I has massive problems when I had the Wellbaum shorty brass radiator I bought from Speedway back in 93 or so. With a warmed over 350 it would run 225 and in Houston traffic in the summer it would get to 240 or so. Then when I put the blower on it would run 245+ and start popping seams. I tried everything - high flow waterpump, high flow themostat, no themostat, restrictors, 50/50 antifreeeze, straight antifreeze, water wetter. You name it I tried it. Finally got a Walker Cobra Z radiator and problem solved. Hardly ever see over 195.
If you run straight water and have aluminum heads, BE CAREFULL, you will get calcium buildup and it will block the small water passages in the block and heads. I know, it happened to me. Took the heads off in 2005 and they were all blocked up with hard white calcium. Poked all the stuff out then it all clogged the radiator at the Nats in Mt Home and I overheated on all the cruises. Came back home and flushed the radiator and it looked like snow. Also straight water reacts with the dissimilar metals (aluminum heads, intake and the cast iron block and the aluminum will start to get eaten away in the head water passages. Just about ruined my set of AFR alum heads. Best to use Distilled Water with a water pump lubricant and rust preventative and/or antifreeze if you want to.
