oldtman
someone gave me a 2 x 2 steel tube frame , 4 x 8 table with1/4 in plate top and I added castors. I have a southworth lift table that will drop into a recess I built into the floor so I can roll heavy stuff on and push the button to bring it up to match the table height. When I built the last frame I started with the CCR plans and followed their tack weld instructions and welded in 1 inch beads alternating to minimize warping. I keep a box of horseshoe nails in the top drawer of the tool box. , they are mini wedges that I can use to align pieces if they start to warp when tacking. I have the pieces behind the barn from a commercial demolition job to build a roll around frame jig. I will probably build one like they had in the shop at UVU . check out chris davenport aluminum 40 willis he built from scratch. when I'm down south I'll get some picts and measurements and also copy their louver press. I got all the hydralics from a junk tractor.
