Keeper
Okay I am about to start picking up parts for the front end, but I am confuzzeled as to which front axle I have.
I am pretty sure its a Chevy axle as it had chev spindles on it when I got it.
Pin to Pin is - 50 1/2
Perch is - 40 3/4
Perches are 2 1/4 tall
Codes stamped - 21a 3010 on each end of the axle
It has two shock mount holes in the middle 30 inches apart, though I am not sure they are original. It also has a continuous curve the entire length.
I have looked around for info on the early chev axles and everything just points me to new axle makers.
Thanks in advance.
Perch is - 40 3/4
Thanks in advance.
