Racecar...sure. Street car? No way. A friend of mine built a Pro-Street Rambler wagon and did a drag style motor plate solid mount. It was mostly a drag car but he did run it on the street some. The next year he fabbed up some cushioned mounts as he didn;t like how it acted with the power of the engine (an ex Gaerte sprint car motor) He had enough of the rigid mount and reported that he liked the rubber mounts a whole lot better on the street.
I don't think you have to go with stock style mounts but some bushing style mounts work pretty good. Here are the ones I fabbed up for my 27 (SBF). I used a stock-style tranny mount.
Oh yeah, before Ted jumps in, I used ARP bolts and the nut on the frame mount was replaced with a thin Nyloc.
I just wanted to compliment you on this motor mount. The design is simple, yet real neat. I like it! Is this some of your work?
I myself would have made the tube mount that bolts to those two cast bosses shorter, to lessen the leverage... Then made the frame mounts a bit longer and grabbed more frame, from top to bottom of frame... Also that tubing you used looks a bit thin to me... Big dips or bumps in your travels will work very hard on that mount, even as nice as it looks... I have seen too many engines fall out of the frame... BTDTPS, The bigger the rubber bushing, the smoother the ride...
Ben, What did you use for the bushing?
Ted: That tubing is genuine 4130 chrome moly tubing... it'll handle anything that motor has, and the bumps and vibration too. No issue with a smooth ride!
Ron: The bushings are Energy Suspension 4 bar bushings.
Clean work on the mounts, Ben. I always appreciate little details like that, knowing full well they are the types of things that generally go over-looked.
PotvinGuy, I can only echo what everyone else has been saying. You would be amazed at the amount of vibration transmitted into a frame when using solid mounts. If you really feel they are necessary to prevent tearing up rubber mounts, try to come up with a limiting cable to restrict movement in that left mount. Yes, it will look like a wart on your nose, but it will keep the vibration to a minimum. If you go with a solid motor mount, I recommend using a mid-mount as well and then completely eliminating the trans mount. That is not a typo - do not run a trans mount at all, if you're tying the engine solid.
This is another race car trick best left to the race cars.
Mike, who told you about my wart? Thanks for good advice. You and the others have convinced me. Anyone know of some really slick mounts off the shelf?
