Got the GHP mockup kit, arrived last Thursday November 7th. It includes what you see
below. It has extra pieces at my request, so I would have the option to design a Tri-Y design
"4 into 2 into 1" (4-2-1) ...
OR ... the traditional "4 into 1" (4-1). Therefore you will notice
that it has six 2-1 collectors and two 4-1 collectors.
I needed to document the frame angle as it sits on the safety stands so I can make my
last collector parallel at 3.1°.
John (ORF) came over to see what's going on, he is always supporting me with my projects .... thanks John!
John actually did what you see in the first pic. You will notice I'm trying to keep the last
collector inside the rear hair pins, so the wife does not get burnt again. It certainly is adding
another level of complexity as I try to get the primary tubes around the steering.
Take a look at those 2-1 collectors, they are what's called a Merger Collector. They don't
abruptly end in a bigger tube like the traditional 4-1 collector, they merge at an angle or
around of 15°.
OK if numbers give you a headache, this is where you stop reading !!!
Do NOT go past this point !!!
Now try to configure those primary tubes while also meeting the dimension below. First graphic
is the inputs and the 2nd graphic is the dimensions that Pipemax 4.5 is giving me. Oh, btw you
will notice that I paired cylinder 1-3 and 5-7, that's not the optimal union for a SBC firing order
of 1-8-4-3-6-5-7-2. John and I both agreed it would be nearly impossible to pair cylinders 1-7
and 3-5, oh what a headache these requirements are turning out to be !!! I have posed this question
on the Pipemax forum to see what Larry Meaux says about how important cylinder pairing is.
I've highlighted the important dimensions that I'm trying to meet. I'm not entirely sure I
understand them all, so I've also posted a question on the Pipemax forum to clarify.
