Until yesterday I'd been planning that my frame would have a short Z kickup on the front end, to clear my rack and pinion steering. Yesterday it dawned on me that somewhere in the evolution of the frame layout, the R&P unit was almost perfectly aligned with the center line of the main frame rail. Today I experimented with doing away with the Z kick-up, and running the the R&P bellows through a minimum 3" ID sleeved hole in the main frame rail...see below.
My questions are, with a 4"x2"x 1/8" frame rail, a 3/16" wall sleeve, is a sleeved hole of that size going to weaken the frame too much? Would a thinner wall sleeve, and leaving more of the frame sides intact be better? Or would going the other way, and going with a larger OD thicker wall sleeve be best? Should I scrap the whole idea, and go back to the short Z kick-up?
