Horn Relay
I think the relay you have will work but think you have reversed the bottom two leads.
onio,
That hand drawn diagram shows a blocking diode across the coils leads. Since the diode is used for blocking voltage flow, the cathod side (tip of triangle with the short line drawn) will be your 12 VDC + from your fuse block.
If the horn on the column grounds out to the column when pushed.
Wouldn't I be shouting out the relay when I push the horn, if 12v+ is running to the relay.
I tryed that. Nothing happens. No horn or spark.
Autozone has the 40 amp 4 prong relay.
Flaming rivers site says how to wire it . :)
40 amp relay
I'll try that one tomorrow.
Ok, Replaced the relay. Works perfectly now :bow: woo hoo.
Thank you for the help
Thats an easy one horn on the top power on the bottom left and ground on the bottom right that would be the horn button.
