It looks tougher than it is I think. It is pretty mushy when you manually push up and down on the front end. Haven't driven it yet but am willing to take some of those out if it is too stiff. Most of those leafs are almost 100 years old off of a real 1920 something T. They have understandably aged and apparently lost some muscle. I just love them for the nostalgia.Jim,
That sure looks like a very stout front spring. Have you driven this car yet with that
spring, I'm thinking you will want to remove some of those leafs. Just a guess.
Those little teflon pucks are in there although I thought they were just plastic and really had no idea what their purpose was.Those springs with the round bumps are Posey leaves I think. There are Teflon pucks to soften the ride.
Quieter tooThe pucks reduce the friction of each leaf rubbing against the other It's a good thing.
Took out the front two driveshaft hoops and replaced with a square driveshaft cover. Left the rear, most important, hoop alone as it is located outside the bucket. Set up the driveshaft cover so the shifter would be in the right spot. Seat brackets are tacked in place. Now that I have a nice "square" driveshaft hump to play with, I plan to cover it with sheet aluminum just like the floor. I have never even ridden in a T-bucket but this one is beginning to look more and more like a go-cart on steroids.
