40ford
Youngster, since you mentioned Ray Sisemore's T build up in Car Craft mag in '64-'65 in another post, I pulled mine out and took another look at his build. His T has so much ground clearance it almost looks a like a jacked up 4x4 pickup. Now on to the question. How do you come up with a close approximation of frame ground clearance when setting up your frame and suspension? Would you use a front spring perch that was higher than his and a higher rear frame kick up? The reason I ask is because my friend that I sold my '46 Ford to is not going to use the flathead engine and running gear. We are working on a deal and I thought I could use your frame plans and his build up and build a flathead powered T.
Ron A
Ron A
