Gerry
Hmmmmm ... back to the drawing board
Maybe not. Its worth a try. Im sure you can figure a way to install it your way with a bit of thought and some thicker parts. After all; IF your brakes failed you would want to go through the car to see whats happened. Then you could evaluate if the tie bar mouting stood up to the job.If it was me, I'd go for it.
I mounted my bracket on the nearside (American) so that all the force would be up through the bracket, not down. This means the force is transferred into the chassis, not to the welds holding the bracket on.
You got to give it a try.... aint you?
Gerry
