Looks like you could run a deeper wheel to the inside to get things closer to the body... and, they do make special shims that mount between the U joint flanges and the rotors, to get your tires sitting straight, or as you like them, a bit positive before loaded... run flat, more traction and less wear...Lee_in_KC said:Mine is stock width. It came out of a '77 XJ6 and is 61.5" hub to hub. I have thought about narrowing it, as I would like my tires closer to the body.
Ted Brown said:Well guys, do you see a problem here?? a few for that matter... First look at that axle, the third member is way too low, the frame kick needs to be higher, so as to straighten out those axles, as that is what wears the tires out on the inside. also, those bent tube braces from the bottom of the third member to the frame are pretty much usless... Those rods need to be more forward and kept straight, as they take a lot of stress, unless you do use a workable, long set of radius rods, which is really what this set up needs... and do not then need those short brace rods. As they will just bind things up this way... a fight between the brace rods and the radius rods... one says stop and the other says come with me..
Hey Ted, I have done exactly as you suggest. I bought a new set of Center Lines with 1.5" more backset than the ones I had... leaves me about 3/4" clearance between the wheel and the bottom of the hub carrier. I have also adjusted the camber shims to get zero camber at ride height. Tires are wearing very evenly. My half-shafts sit level at ride height.Ted Brown said:Looks like you could run a deeper wheel to the inside to get things closer to the body... and, they do make special shims the mount between the U joint flanges and the rotors, to get your tires sitting straight, or as you like them, a bit positive before loaded... run flat, more traction and less wear...
