PaulR
I have a Painless Wiring kit # 10308 that I'm using to wire my bucket with. It has LED front turn signals ( 2 wire) and rear 38-39 FORD LED lights from Speedway (3 wire). I have a resistor for each of the LED lights so I should not need an electronic flasher. At least that is what I can gather from the web.
I want to use a simple on/off/on switch for my turn signals. I have read the instructions for the Painless kit and they seem to not cover anything other than using a standard turn signal on a column for a GM/Ford or Mopar. I don't want anything on the steering column except the steering wheel. Any guidance would be appreciated.
Please forgive any spelling errors as the 'way better half' and I celebrated Cinco De Mayo early.
PaulR
PaulR
